What's the most important part of your camera?
  • Lens optics
    Votes: 52 65.0%
  • Vewfinder
    Votes: 11 13.8%
  • The film in it
    Votes: 12 15.0%
  • The name on front!
    Votes: 5 6.3%
  • Total voters
    80
everything is important!
but what's the use of an excellent lens, a bright viewfinder or
a high-tech camera,with no film loaded or with a bad film?!
Something not mentioned in your poll: the shutter. The lens? The lens is not necessarily a part of the camera, and on some of them can be changed if you don't like it. The viewfinder? Some cameras (view cameras, pinhole cameras, and etcetera) don't even have viewfinders, but you can still take good photos with them. Film? If you don't like it, you can change it, and it is not (again) part of the camera. The name on the front is utterly inconsequential. If your shutter is malfunctioning though, you're pretty much screwed.
Hm, I voted viewfinder, but Fallis argument is valid. Bu since I only use 24x36mm film or sensors, I stick to the viewfinder. That's what I see through and thus determines when I release the shutter, which hopefully doesn't fail 😉
I like a good viewfinder.
Ergonomics are big too. The feel, how seemlessly I can manipulate and hold the camera so it's an extension of me. But that's mostly a function of time, even a bad design can become second hand.
The lens is important, but provided the camera can mount a range of lenses (LTM/M) whatever, then that's adjustable. But if the camera interferes with seeing well then all is lost.
The name is ridiculous. I suspect that the OP put that in there for humor.
In answer to FallisPhoto, perhaps another way to ask this question is as follows ...
Assuming that you are out with a camera that was given to you, and had only that one, and you were to be asked which of the parts I've chosen in the list (including whatever film HAPPENED to be in it) would you sacrifice the quality/usability of LAST, in order to acheive what YOU want photographically?
For example, is the lens that happened to be on that camera at that time the most important to your objectives, i.e. sharpness, contrast, later enlargability etc.? Or is it the specific type of film you use that could possibly define your work more than anything else, like say Tri-X? Or is it the usability of the viewfinder (assuming of course the camera has one in the first place!) that is the one over-riding thing that must be right FIRST in order to facilitate your photographic objectives and allow you to work the way you do in that regard?
Yes, you could list a whole lot of other things like the shutter in a camera etc. because it is obviously a part of the camera too, but I wanted to stick here with what I think are the three most obvious ones that - depending on their type/standard etc. - are the very things that facilitate both your vision and the characteristics of your end result, for YOU as a photographer, personally. I don't mean to open up issues regarding whether the film, or the lens or whatever else, can be deemed a part of the camera or not.
I put the last 'name on it' option there both as a bit of humour and for the fact that there are people I know that will ONLY EVER shoot with a specific brand, perhaps for psychological reasons. Therefore, they can't BE photographers at all without their beloved 'Nikon', 'Leica' etc, because perhaps they cannot be 'in the(ir) zone', so to speak, while they are shooting unless they KNOW IN THEIR MINDS FIRST that it's a 'Nikon' or whatever in their hands.
I think it's just a very nice simple question and an important one as it helps me to very efficiently shortlist some possible cameras I might plan on acquiring and using in the future. And I was curious to see what proportion of people (ballpark figure is fine for me) might be of the same mind in terms of their camera's viewfinder usability being the most important thing on their camera that allows them to acheive their photographic objectives more than anything else.
Film: the other stuff isn't important to me. I hope this cheap, cheap 6x6 proves good, have you ever seen one?
Some great answers here, I must say! 😀
Keep 'em coming!
Judging by a lot of responses, I should really have put as a 5th option "other (please explain)", so it's pretty cool that people are doing that themselves! 😎
Later, somebody can collate all the funniest responses and put up a new poll to vote for the best line from this one!
Well, given only the choices here, I guess I'd go with the lens. I could bracket like hell and eventually get the thing aimed in the right direction, so it is possible to take good photos with a lousy viewfinder, although it would be a pita. I could try different developers until I found one that would give me acceptable results with a film I didn't really like. As I said earlier, the brand name is utterly inconsequential to me (I have absolutely no brand loyalty). If I had a bad lens, there may not be a whole lot I could do about it though (there are some exceptions to that last though -- For instance, a few years back I installed a dialset shutter and lens from an old junked Bessa on a Foldex 20 and -- with a little tinkering -- it worked).
On the other hand, I was once given a Quantaray zoom lens, for my Pentax K-1000, as a gift (from a well-meaning, but clueless, relative). Well, it sucked, as Quantarays often will, so I tuned it up a bit, like this: http://www.kyphoto.com/classics/kironlens.html That made it a little better, but not enough. Currently that lens sits in a drawer and I don't guess I've used it in over five years; that's how long ago I attempted to fix it. There just isn't any situation I can think of where a dim lens that won't focus properly is going to be of any use to me. I keep thinking one day I'm going to take it apart to make loupes.
this clarifacation makes the question a little more simple...but only a little!
before this my first thoughts were the lens as the body is just the light box behind the lens...but then i thought it depends on what i want, if i need a particular feature then the body is most important e.g. a view camera with movable standards or many other features many different typs of rangefinders have and on an on it went .....just too difficult to answer which is why some folk are using humour in reply i feel (it cracked me up the one about the kind of screws used! LOL)
but if the camera body is already selected and it is a model with fixed lens then i choose one that has the best lens in its available offering fitted. if it has interchangeable lens capability and a rangefinder camera then the viewfinder has a lot to do with a final choice given the restraints of the choices.
actually this is still running me around in circles...i still havnt voted as its too hard for me to choose!
actually now i have voted..i chose the name on the front....that way i reasonably sure i will get all i need from the camera. lieca, haslleblad, ebony, and the list goes on...and dont forget the old Welta ;-)
The brain of the person making the thing work. Without that, it's just pieces and parts.
All those optics, mechanics, and electronics take a far distant back seat to the brain, eye, and soul of the user.
Shutter release.
Better a single-use camera that takes a picture when I want, than an auto-everything camera that takes it too late.
As a friend said of a Nikon digicompact, "There's no way I'd try to photograph the girls with it [his daughters were 5 and 8 at the time] because by the time it took the picture they'd be wearing make-up and going out with boys."
So true Roger!
I'm principally a film shooter, and with RFs now more than SLRs, and I've never had the 'pleasure' of shutter releases that don't actually release when you need them to. So I've perhaps unwittingly underestimated the importance of that as a camera part - the characteristics of which might completely handicap your photography if it's the one thing that's not right for your shooting needs.
So shutter SPEED might be considered too in that regard: if you were say a photographer who does dusk seascapes (with the blurry water etc.), if you didn't have a shutter that went to seconds you'd be pretty much doomed. Or if you needed to do a lot of fill flash outdoors, an SLR with a max. sync. speed of only 1/60th sec. might cramp you style a bit!
None of the above.
I would have to say the base plate. Without them I'm afraid images on my M6 bodies would be terribly overexposed. :angel:
Yeah, but some of those companies made several entirely different kinds of cameras.
A well designed camera is akin to an organic whole in which every part has a role to play. My M2 has no self-timer, which is acceptable; and I expect I could live without the frame preview lever and the film reminder. All else is essential.
