Leica M body disassembly, painting, ...
rlouzan, thanks for the links to random softreleases. Ginichi looks interesting and quite small compared to ones from Luigi which I have.
I saw one tiny but with larger diameter red colored on a M body somewhere in a picture. Does anyone knows of it? I say it is quite tiny almost like Ginichi. Maybe it is the same?
Beautiful looking Ms. As for Bablefish translation, I don't know....🙁
In Leica, most model which Leica seems as for that when it is heard what as for me we would like to call M2!
But as for Leica M2 the model which appears in 1957, positioning becomes the spread machine which assures the cost decrease of the first class machine M3 which is sold first. First cost decrease with structure of the finder, from highest M3 where all optical axes mix vertically, was refracted light, was improved to the structure which decreases lens constitution. But, the fact that the finder to whom this structure is taken over to current new model, MP even M type Leica basic shape can say result is produced is this M2. However, as for the structure which designates the automatic restoration type counter of M3 as the manually operated external counter, with MD, and the special model originator MP who are excluded, most as for the feature appearance of M2, it probably is this external counter to M1 and the finder who furthermore abbreviate the range finder from M2.
Until it starts from No926001 1957 make and ends M2 with M2R type No1250200 1970, 87.567 units are produced truly, specification modification of many degrees is done. When you write in detail, because being able to produce HP it finishes even just this M2, it abbreviates, but those where it has the absolute existence impression in the difference of the eye which was seen, only the only 2000 units probably are the black paint specification which is not produced. Especially, the external film counter the black paint and affinity is good, closely resembles originator MP black truly [katsukoii]! But, this black paint specification is a big fault. As for that there is paint of that time. That Leica doing the coarse paint like the lever is strange, but the deterioration which is problem on the material of peeling and the paint of the paint with the adhesive malfunction is greatly terrible. Leica where the original as for the black which is written the material of the brass is visible in the old market, is beautiful the form which is the counter electrode, furthermore, just calls the original this and is high!!!
Then, the Messiah with technology and the paint of today [ripeinto] the model which is done. Calling [ripeinto], to exfoliate plating the silver chrome with all chemicals, to brass material after as for the distance which it bakes and is painted being the same as the real thing, the original way there is no either worry where paint comes off at a stroke. However, when you ask this to the trader, but as for 100,000 Yen when preparedness necessity (good [ripeinto] is desired), if [ripeintomoderu] of the used item, unexpected it is cheap. Because the reason is considered “[hueiku]”, but is, rather than paying your high money in original coarse paint, the person who buys clean [ripeintomoderu] cheaply probably is wise?
This [ripeintomoderu] which I inserted in the hand was 189,000 Yen, it was a in splendid state, but quality of paint and being perfect, a scar completely there is no. Furthermore, also or the operation which are the overhaul being completed being quiet, it hoists in Leica which presently owns, it is one rank of [dantotsu] in feel and shutter sound. That it is one unit which agrees upon whether this, it is the true height of Leica which is produced in peak period.
The lens which you have installed is the silver of current [zumikuron] 35mmF2.0 [asuhuerikaru], but because this silver is the brass make, [zushiri] it is heavy, also Leica of the black paint affinity is good. Next, the Leica M grip of silver one make and the finder of [abenon] are installed.
Tomasis,
http://www.rapidwinder.com/
Tom Abrahamsson´s Classic dome shaped
Diameter: 15mm
MiniSoftrelease
Diameter: 10mm
http://www.rangefinderforum.com/forums/showthread.php?t=45065
http://www.rangefinderforum.com/forums/showthread.php?t=47746
Regards,
RLouzan
