pevelg
I have been wanting an extra body for sometime now. I need it so I can take it on the go, in my pocket, without fear of loosing or damaging it. My choice was thus the FED2, the FSU that is so loved by many on this forum. I purchased the item from )@^*%bay, a good seller, and transaction went smoothly. Well, item was not as described and had several issues. The minor ones were fixed (loose set screw in speed selector making select spin aimlessly leaving you to guess the speeds). The lens was very poor as well. I was thinking about returning the item, but as I paid only ~$19 for the item (minus shipping, I bought another item from them as well), I decided that it would not be worth it. So I found the sticky here in the FSU forum on playing with the FED2 and here is my results:
This photo is taken with my 75mm Color Heliar on Leica M6TLL with SF20 flash on Kodak BW 400CN. My Leica is laughing at the detestable object lying in the dish.
Progress is slow. At this point I am unable to take off the rangefinder window. I leave to town to look for a sutable tool to remove it. After several hours I return with nothing. :bang: My Leica is beeming with delight, knowing it's superiority.
My Leica blushes. It is the first time she has seen a naked Russian.
To my Leica's astonishment, I manage to FINALLY put the FSU together again. After securing the the top plate, I had to remove it again to fix an error I did. To my surprise the inside was relatively clean. I used alcohol to clean everything and then carefully cleaned all the glass and put it back without dirting it. The result was amazing. The viewfinder and patch looked MUCH better.
I shot this image around ~5 times at proper exposure and ~5 times at +1 stop, keeping shutter at 1/50. All images looked like they had equal exposure (later five had hardly changed other than a narrower DOF). So it seems like the camera MAY just be ok. Tomorrow I will put in some color film and test shooting houses and cars with maximum DOF.
Here is a picture with the Industar 50 at f3.5, shutter speed 1/25th. I took 5 images at this setting and all looked the same. Again, more tests tomorrow. You can see my dejected Leica laying on the sides. She knows now that she won't get all my attention. I wonder what she'll think once my hassy system comes in!!! 😀
All shots taken with the same roll of film. Wow, I love manual cameras!!!
This experiance has been somewhat trying, but overall very rewarding. I am definetly going to be keeping the camera. The lens is another story though.... I need to replace it with a collapsible so the system can fit in my pocket.
I found more instructions on how to CLA the rest of the camera. I nearly cried. I hope tomorrows test turn out OK and no more work needs to be done.
