Help with lens desicion!
peepete77
6:41 PM
Hi!
I am thinking of trying a Single Coated lens, and I have laid eyes on VL 35/1,4 and 40/1,4. The 40 is cheaper, does this mean lesser quality?
Also, if someone would like to post shots taken with these lenses, it can even be the same in multi-coat edition, please let me see... I am really curious.
I have searched flickr, and seen some good shots, but I am not convinced.
Is the 35 so much better than the 40 as the price "says", and is there really that much differnce between Multi coat and Single Coat?
Thanks, I am anxiousely awaiting answers here... Almost can't wait! 😉
If anything the 40mm is of higher quality. The 35mm has a bit of barrel distortion but the lenses are pretty much the same. The 40mm matches much more closely to the conservative 35mm framelines of the R-D1.
I think the 35 is more expensive because it is more complex (1 more element) and that 35mm lenses are much more popular in general.
Surely a 40mm would give a 60mm equivalent on a R-D1?
//Jan
Interestingly the 35mm frame lines found with the RD-1 give a fairly accurate FoV for the 40mm Nokton. A number of folks here, including myself, have found this to be true. I have the multi-coat version. It's a great lens.
. . . Burkey
I found the 35mm framelines to be an accurate match for the 40mm Nokton except for the bottom part. Don't know why, but I always got the feeling the bottom part of my pictures came out tighter than I expected.
Apart from that, a wonderful lens for night shots, a bit too tight for daylight IMO.
The 35/1.4 SC is very good at f/1.4. Good sharpness, smooth bokeh. Sharper at f/1.4 than my favourite Summilux pre-asph 35/1.4. Flare is rather high though and from f/2.8 to f/5.6 it is difficult to get sharp results. This would be due to focus shift according to some reviewers.
