totst
The shutter speed ring lifts up easily and the front part is kind of loose. Any ideas? Links? Thanks.
Clark.EE
7SII Repair
7SII Repair
I bought mine with a similar problem,(cheap) but it was so bad the wires to the meter had worn through, the front of the lens element had almost fallen off.
You will need a rangefinder spanner to undo the retaining ring around the front lens element. There are two tiny grooves that you could try a jewellers screwdriver in, just in case its loose. be very careful, you are close to the front element.!! I could not find anything on the web to help me, or anyone on Rangefinder forum to help.
Once you get the ring off the front its quite straightforward.
A retaing ring i think will need tightening, and the screw that stops it moving
(This may or may not be behind front lens element)will want a bit of clear nail polish on to stop it moving again.
Cant really remember its that long ago.
Getting a spanner would be a good step.
Or you could sell it to me?
Happy Tinkering........
Chris
7SII Repair
I think this is a problem with the 7SII.The shutter speed ring lifts up easily and the front part is kind of loose. Any ideas? Links? Thanks.
Chris
totst
It's fixed. While doing the repair work the aperture stuck on a constant opening. Took off the top and bottom and it worked itself back to normal. I wonder why this happened? Noticed that when it stuck the meter needle was between f16-f11. Taking off the plates brought it back to f1.7. I'm perplexed. But happy that it works now. Thanks.
camera.bear
Congrats on getting your 7sII up and running. I know that I really enjoy shootting with mine. I hope mine doesn't develope a problem like this. The lens is solid so far.
