Rob-F
Likes Leicas
I mean the $19.95 ones on eBay. I wonder-- are they precision made? I'd rather go for the CV ones if there is anything cheap or inferior about the ones that come out of Shanghai. Who has tried one?
I was recently wandering about this equation: Wrong adapter thickness = wrong focus. I reached the following conclusion: The wrong thickness moves the whole lens from its right position, including the ring that pushes the RF roller. It shoud thus still be indicating the right focus (the roller is pushed just by the amount coresponding to the lens optical position.). The only problem would be at the extremes: infinity or close focusing, the lens could stop before or after the point it was meant to.I have a couple of the chinese adapters - and, yes, they are cheap compared to the CV/leica ones and out of the three I have, 2 worked fine and the 3rd one had the plating put on too thick and also flaking badly. I used it on an old Jupiter 85f2 and it did "kick" in the 90 frame, but it took some work with a files and a steel brush to clean up the threads enough to go on the Jupiter! Once on - it wants to stay there and I now have a m-mount Jupiter 85!! Oh, well, the total cost for the lens and adapter came to less than $25 - so who cares.
I would not hesitate to use them on wide angles as the depth of filed would more than offset the minimal focus shift imposed by the thicker or uneven plating. For long and fast lenses (85f1.5 Canon/Nikon, Summarex f1.5, 90f2 Summicron) I would spend the money for either a CV or a Leica adapter.
Of course that suppose that the adapter thickness is at least uniform (or else the lens sits with an angle)
Does that make sens??
