RichardB
The M7 has a little dot in viewfinder that appears and does not flash when the shutter is partially depressed to indicate the exposure is locked. Its really the same as using an external meter in that you expose on the portion of the scene that you want the exposure for if you have a high contrast scene. Partially depress the shutter until the dot lights up and then frame and shoot.
If your subject does not need this then just go ahead and shoot, I have two M7's and they are ther best of the lot. Only drawback is if using Motor M's in that the initial exposure if locked will not be retained for further exposure with the Motor M. You really need to use an M7 and draw your own conclusions.-Dick
