dfoo
I've developed hundreds of rolls of 35mm and medium format over the past few of years, and apart from the very first roll when I didn't use enough developer, and an adventure that saw me destroy a couple of frames out of a roll of delta 3200 I've never messed up a roll of film. Today I wiped out my first. I decided to try to use a steel reel and tank that I got with a recent purchase. Before I've only used plastic reels. As long as the reels get a good scrub with a toothbrush every few months, they've worked great. The steel reel, not so much! Half of the film was stuck together, and I made another cardinal sin. I didn't put enough developer in the tank. Its a pity, because I think there was some nice shots on the roll. The first half of the film went well on the reel, but the problems started in the second half. I'm debating tossing the reel, and sticking with the plastic! For sure, if I use it again I'm going to practice with some old film.
The film was my old standby TriX exposed at EI 400. I also used rodinal for the first time. I tried 1+50 dilution, for 13 minutes at 20 degrees. I agitated continuously for the first 30 seconds, and then 5 seconds every minute. The negatives that were developed have good density, but I'm frankly very surprised at how grainy they are! Compared with D76, XTOL, and HC110 the grain is very very prominent! Is that expected, or was it a function of the agitation?
