Well, I just finally came around to clean my M8 myself... I have been doing a fair amount of repairs previously, and know a few tricks for getting a glass surface 100% clean. Still, this was NOT a walk in the park I feel!
I kind of knew that the dust specks would not come off easily, none of them even moved when I used a blower... I guess they had been embedded by condensation during the winter. After a double swipe with wet cleaning, there was not the tiniest difference.
What I ended up doing, was going after the specs almost on an individual basis - figuring out about where they would be from the exposures. This worked, and it seems that the extra pressure I got from not applying pressure all along helped.
But I must say I was really nervous in the middle of the process!
I guess that next time I will try to get the cleaning done earlier, so that the dust does not settle for real.
The only thing that I am just a little concerned with now, is whether there is any coating that may be worn off after excessive cleaning? I am sure that it would really take a lot of aggressive cleaning, but is it possible after all?
Also I wonder if there is any way of dealing with hard particles like grit or metal dust, IF any of the specs I had was anything like it I might have run into a real problem...
Maybe get a cheap microscope??? 😀
