mojobebop
thought i read the dr summicron 50 does not work on
all m7's.
does anyone have any info on this?
thanks
all m7's.
thanks
peter_n
All I can tell you is that it worked on both of mine.
Rob-F
Likes Leicas
M7 and M6 TTL have top plates that are a little higher than other models. You may need to remove the little black plastic stud that is meant to stabilize the goggle finder accessory by resting on the top front corner of the camera. It unscrews, as I recall. Without the goggles fitted, there is no issue at all.
mfogiel
Yes, it works - M7, DR Summicron:
Beemermark
Works on my two M7's. Lovely lens.
CK Dexter Haven
I had a .72 M7 for a while, and the DR worked on it very well, after removing that same bumper/screw described by Rob-F above.
RichardB
I have two M7's, my DR works on one and not the other.-Dick
Vincenzo Maielli
Surely yes. Mine is fixed on my MP, but work fine also on my M7, actually married with Summicron 35/2 eight elements. Both are fantastic lenses.
Ciao.
Vincenzo Maielli
Ciao.
Vincenzo Maielli
peter_n
I have the same pair Vincenzo!
matt335
mojobebop
beautiful shot.
curious about film/developer.
i typically use tri-x/hp5.
hc-100/dilution b.
---------------------------Yes, it works - M7, DR Summicron:
beautiful shot.
hc-100/dilution b.
Vincenzo Maielli
Wonderful shot, Mojobebop.
Hi, Peter n: sooner or later, i will visit the USA and particularly Boston, the first town of the rebellion against the english rule.
Ciao.
Vincenzo
Ciao.
Vincenzo
chris00nj
Young Luddite
I've read that the Summicron DR doesn't work on the Bessa R2 series. Does that only mean the lens with the goggles? I assume that it mounts without the goggles?
peter_n
As an Englishman living out here in the ColoniesWonderful shot, Mojobebop.
Ciao.
Vincenzo
Vincenzo Maielli
Whit very pleasure! Fantastic english sense of humour!
Ciao.
Vincenzo
Ciao.
Vincenzo
