srtiwari
Daktari
Something is clearly not right. They should NOT be so obviously soft. The following information may help-
Which particular holder are you using ? The Variable height ones may require testing at different heights. Also, don't mean to offend, but are the negatives quite sharp ? Was there a lot opf warp to the negatives ?
I have used both, the v700, and the Nikon 9000. The latter is better, but not by much. In a few minutes, I can scan and post something from my V700, if that will help.
Subhash
Subhash
