Compatibility of Nikon S / Contax RF lenses on Leica M with Amedeo Adapter
jonmanjiro
Moderator
Staff member
7:24 AM
Yokohama
Disclaimer: I thought about starting this thread in the Nikon forum, but decided to start it in this forum so it can be a combined resource for both Nikon and Contax mount lenses.
Background: Lately, there's a lot of interest in Amedeo type adapters for mounting Nikon S-mount lenses and old Contax mount lenses on M-mount bodies, so its about time we had a registry of what lenses can/cannot be mounted and used on M-mount bodies via these types of adapters. Feel free to add more information and fill in any gaps, especially concerning Contax lenses as I have no experience there.
Compatibility: Generally speaking, all internal mount 5cm/50mm lenses, and I think most external mount 5cm/50mm and longer lenses, work fine (although confirmation is needed on some lenses). It's the wide angle lenses with large rear elements that create problems. Below is a list of Nikon S-mount lenses (I may have missed some so please add them if I have) with a comment on compatibility for each lens.
For reference, here's a list of the Nikkor lens designations. In the case of the Nikkor wides, "W" just means "wide".
T= three elements
Q= four elements
P= five elements
H= six elements
S= seven elements
O= eight elements
N= nine elements
U= ten elements
UD= eleven elements
NIKON S-MOUNT COMPATIBILITY LIST
S-MOUNT NIKKORS
Nikkor-O 2.1cm f4 (NO - rear element too large, interferes with rangefinder mechanism)
W-Nikkor 2.5cm f4 (NO - will mount but cannot be focused)
W-Nikkor 2.8cm f3.5 (YES - will mount and focus from infinity to 6ft, but may come into contact with focus cam between 6ft and 3ft)
W-Nikkor 3.5cm f3.5 (YES - will mount and focus properly)
W-Nikkor 3.5cm f2.5 (YES - will mount and focus properly)
W-Nikkor 3.5cm f1.8 (vintage/reissue) (NO - rear element too large, interferes with rangefinder mechanism)
Nikkor-P 5cm f3.5 Micro (YES - will mount and focus properly)
Nikkor-H 5cm f2 (YES - will mount and focus properly)
Nikkor-S 5cm f1.5 (YES - will mount and focus properly)
Nikkor-S 5cm f1.4 (YES - will mount and focus properly)
Nikkor-S 50mm f1.4 (Olympic/Millennium) (YES - will mount and focus properly)
Nikkor-N 5cm f1.1 internal mount (NO - rear element too large, interferes with rangefinder mechanism)
Nikkor-N 5cm f1.1 external mount (NO - rear element too large, interferes with rangefinder mechanism)
Nikkor-P 8.5cm f2 (YES - will mount and focus properly)
Nikkor-S 8.5cm f1.5 (YES - will mount and focus properly)
Nikkor-T 10.5cm f4 (YES - will mount and focus properly)
Nikkor-P 10.5cm f2.5 (YES - will mount and focus properly)
Nikkor-Q 13.5cm f4.0 (YES - will mount and focus properly)
Nikkor-Q 13.5cm f3.5 (YES - will mount and focus properly)
SC/S-MOUNT VOIGTLANDER/ZEISS
Voigtlander SC Skopar 21mm f4 (NO - rear element too large, interferes with rangefinder mechanism)
Voigtlander SC Skopar 25mm f4 (NO - rear element too large, interferes with rangefinder mechanism)
Voigtlander SC Skopar 28mm f3.5 (NO - rear element too large, interferes with rangefinder mechanism)
Voigtlander SC Skopar 35mm f2.5 (NO - rear element too large, interferes with rangefinder mechanism)
Zeiss S-Sonnar 50mm f1.5 (YES - will mount and focus properly)
Voigtlander S-Nokton 50mm f1.5 Aspherical (YES - will mount and focus properly)
Voigtlander S-Skopar 50mm f2.5 (should work - confirmation needed)
Voigtlander S-Heliar 50mm f3.5 (YES - will mount and focus properly)
Voigtlander S-Apo-Lanther 85mm f3.5 (YES - will mount and focus properly)
S-MOUNT LENSES BY OTHER MAKERS
Fujinon 5cm f/1.2 (should work - confirmation needed)
W-Komura 35/2.8 (should work - confirmation needed)
Komura80/1.8 (should work - confirmation needed)
Komura 135/3.5 (should work - confirmation needed)
Soligor 135/3.5 (should work - confirmation needed)
W Tanar 35mm f/2.8 (should work - confirmation needed)
Tele-Tanar 13.5cm f/3.5 (should work - confirmation needed)
Zunow 50/1.1 (should work - confirmation needed)
Here's the list for Contax mount lenses (help me out here guys!).
CONTAX C-MOUNT COMPATIBILITY LIST
CARL
ZEISS CONTAX (C) MOUNT LENSES
Zeiss Opton 21/4.5 (confirmation needed)
Carl Zeiss 21/4.5 Biogon (confirmation needed)
28/8 Carl Zeiss Jena Tessar (YES - will mount, not focus-coupled)
35/4.5 Carl Zeiss Jena Orthometar (YES - will mount and focus properly)
35/2.8 Carl Zeiss Jena Biometar (YES - will mount and focus properly)
pre-WWII Carl Zeiss Jena 35/2.8 Biogon (NO - rear element too large, interferes with rangefinder mechanism)
post-WWII Jena ("E. German") coated version (NO - rear element too large, interferes with rangefinder mechanism)
35/2.8 Zeiss-Opton (NO - rear element too large, interferes with rangefinder mechanism)
35/2.8 Carl Zeiss ("W. German") Biogon (NO - rear element too large, interferes with rangefinder mechanism)
35/3.5 Zeiss-Opton (NO - rear element too large, interferes with rangefinder mechanism)
35/3.5 Carl Zeiss Planar (NO - rear element too large, interferes with rangefinder mechanism)
Carl Zeiss-Opton 5cm f2 Sonnar (rigid) (YES - will mount and focus properly)
Carl Zeiss-Opton 5cm f2 Sonnar (collapsible) (YES - will mount and focus properly)
Carl Zeiss-Option 5cm f1.5 Sonnar (YES - will mount and focus properly)
Post-war Carl Zeiss Jena 5cm f2 (YES - will mount and focus properly)
Pre-war and Wartime Carl Zeiss Jena 5cm f1.5 (YES - will mount and focus properly)
Post-war Carl Zeiss Jena 5cm f1.5 (MAYBE - large ring around rear element, may interfer with the rangefinder mechanism on some cameras)
pre-WWII 85/4 Triotar (YES - will mount and focus properly)
super-rare direct mount 180/2.8 Olympia Sonnar (YES - will mount and focus properly)
OTHER CONTAX MOUNT LENSES
Nikkor-P 8.5cm f2 "C" (YES - will mount and focus properly)
Nikkor-S 8.5cm f1.5 "C" (should work - confirmation needed)
Nikkor-T 10.5cm f4 "C" (should work - confirmation needed)
Nikkor-P 10.5cm f2.5 "C" (YES - will mount and focus properly)
Nikkor-Q 13.5cm f4.0 "C" (should work - confirmation needed)
Nikkor-Q 13.5cm f3.5 "C" (YES - will mount and focus properly)
Contax-mount J-3 (YES - will mount and focus properly)
Helios-103 53/1.8 works fine (YES - will mount and focus properly)
Kiev 85/2 Sonnar (YES - will mount and focus properly)
wow, great job Jon. Thank you for sharing.
I have used the older amedeo adapter with 50/1.4 millennium on leica m bodies. It works very well and focus is perfect.
Jon,
As always great work.
Sad to see the 35/1.8 will not work, one of the true jewels of the Nikkor line. I wonder if he took a somewhat different approach and abandoned the internal mount for only an external if an adapter could be made? Just a thought as I am FAT DUMB AND HAPPY with my S3-2000.
What about the ZI 50 that came out last summer or so? Wouldn't that be on the list too?
Hope all is well over on that side of the world. Say hi at home from us.
B2 (;->
I (and others) can confirm that the CZJ 50/1.5, CZO 50/1.5 and 50/2, and J-3 Contax-mount lenses work perfectly on the Contax-to-M adapter.
> CZJ 50/1.5
> CZO 50/1.5
> CZO 50/2
I can confirm that the Post War Carl Zeiss Jena 5cm f2 works with an adapter. It is Rigid mount, the optics are larger in diameter than the pre-war version.
The Pre-war and Wartime Carl Zeiss Jena 5cm F1.5 lenses are a different construction and dimensions than the PostWar Carl Zeiss Jena 5cm F1.5. The latter lens does not have ears on the aperture ring.
I have a Post-War Carl Zeiss Jena 5cm F1.5. The ring around the rear group is larger than the Opton and pre-war F1.5 Sonnars, and it can interfere with the RF pickup wheel of some cameras when used with an adapter.
Jon: I have been using some of these lenses on my M8. I have two amadeo adapters (1 Contax, 1 Nikon). I can confirm:
Zeiss-Opton 50/2 Sonnar (rigid) s/n 707611 works fine
CZJ 5 cm/2 Sonnar (collapsible) s/n 2207904 works fine
Zeiss-Option 50/1.5 Sonnar s/n 713519 works fine
Nikkon-S.C. 5cm./1.4 works fine
Millenium Nikkor 50/1.4 works fine
Kiev 85/2 Sonnar (eternal mount) works fine
Voigtlander S-Heliar 50/3.5 works fine
Voigtlander 28/3.5 does not work
Voigtlander 35/2.5 does not work
(both due to rear element blockage)
I have a WA adapter coming from Amadeo. My 50/2 Sonnar collapsible is out in the car -- if the s/n will tell you something special, let me know.
Good idea to start a list.
Ben Marks
[Edit: my collapsible is actually a Carl Zeiss Jena 5cm f:2 Sonnar]
Brian, Ben, thanks for the new information! I've just updated the lists.
Ben, I don't know enough about Carl Zeiss lenses yet to know if I should also be noting serial numbers. Hoping you Carl Zeiss/Contax guys can help me out on this one!
I sold this lens to Brian, and I can confirm his story! It did not focus correctly on my R-D1 with Amedeo's adapter--it was correct at minimum distance and increasingly front-focused towards infinity. According to Brian's tests, it DID focus correctly on an actual Contax. The CZ 50/1.5 I now have does focus perfectly with Amedeo's adapter on both the R-D1 and M7.
Second variation to that list, BTW--my Helios-103 did not fit comfortably into the adapter at first, and I actually had to file down the edge of the barrel to make it fit. It works perfectly now, though. I chalked this up to the probably wider tolerances in its manufacture.
As you wrote, the only inherently problematic lenses are the wides w/large rear elements, the main ones on the Contax side being the pre-WWII Carl Zeiss Jena 35/2.8 Biogon & its post-WWII Jena ("E. German") coated version (plus their Soviet progeny) & the 35/2.8 Zeiss-Opton or Carl Zeiss ("W. German") Biogon & 35/3.5 Zeiss-Opton or Carl Zeiss Planar. All of the 50mm lenses & longer should fit; if they don't, it's caused by differences in tolerances & workmanship between individual lenses (this is particularly true of wartime & immediate postwar Jena lenses & their Soviet progeny) + differences between individual adapters themselves. The tolerances can be pretty tight: an analogous example is that I have 35/2.8 CZJ Biogon that fits fine on my original Nikon SPs, but doesn't quite mount on the S3 2000 or SP 2005, I think because of a slightly thicker area around the shutter in the modern Nikons. IIRC, you had a similar problem w/mounting the CV 50/3.5 Heliar on your S3 2000.
Same goes for all the telephotos (the only 1 I don't have personal experience with is the pre-WWII 85/4 Triotar & super-rare direct mount 180/2.8 Olympia Sonnar).
Other wides that should work:
28/8 Carl Zeiss Jena Tessar (though it isn't focus-coupled anyway)
I haven't tried it, but my understanding is that the Zeiss-Opton or Carl Zeiss 21/4.5 Biogon may work if the rear element protection ring is removed (same goes for the Orion & Orion copies).
thanks for the extra info. i'll update the lists accordingly.
chris, the problem i had with my heliar 50/3.5 not mounting on my SP 2005 and S3 2000 was caused by a slightly thicker locking tab on the lens. just another one of those problems caused by slight differences between samples.
