Bessa R3A battery drain?
Nicolás Raddatz
Excéntrico a sueldo
9:48 PM
Montevideo, Uruguay
Hi all,
I acquired a Bessa R3A a couple of months ago new from B&H. I've hardly run 4 rolls of film on it, and I'm already seeing 1 and 2000 blinking slowly, and at times the shutter won't fire at all. As far as I understand, this is an indication that the battery is about to die. Is this normal? I would have expected much longer battery life, this makes no sense to me.
Thanks
The batteries that come with new cameras are typically not the best and have likely been sitting around for a while.
A new set should last longer.
The other variable is if you're shooting lots of long exposures; that will drain the batteries quicker too.
Rob
