Looking for the "old look" in a 50mm
qruyk12
12:32 AM
Canada
I currently have an MP with the 35mm cron asph and 90mm apo. Great lenses but in BW they are too good.
I want to get a 50mm that has that old unsharp glow you here so much about. Help! Way too many choices...
How bad do you want it to "glow" ?
From lots to little glow (basically veiling flare):
Hektor -> Summar -> Summarit -> collapsible Summicron -> DR Summicron -> 1.0 Noctilux / pre-asph Summilux -> the end (modern glass including newer Summicrons, etc).
You could also try a Nikkor 50/1.4 wide open.
Not sure what you mean by unsharp. If you mean unsharp + veiling flare, maybe try a Canon 50/1.2 ? 🙂
Roland.
Choosing a pre-1950 lens can go a long way to giving what you are looking for, but whatever lens you consider, you will probably have to work at, or naer, its maximum aperture in order to get the look.
From personal experience, I can suggest the Summar, Summarit and CZ Sonnar in LTM, but don't take that as gospel, they are all slightly different.
Look through the photos and choose what You like - then ask what lens it was made with. That's the best way I know! 😉
Summar, or uncoated 5cm f2 Sonnar.
With the Sonnar:
at F4
picture.php
At F2
picture.php
Easily converted to LTM using a J-8 mount, and much cheaper than an original LTM Sonnar.
Personally I enjoy the collapsible Industar 50s, but they are slow.
(The focus on this lens is fine, I just had a bit of trouble getting it while she was walking and I was walking backwards in front of her 😉 ).
Jupiter-8 5cm F2, wide-open on the Canon IVSB.
picture.php
Sonnar "T" 5cm F1.5 in LTM, wide-open on the Canon P
picture.php
1956 Jupiter-3 5cm F1.5 , wide-open
picture.php
Collapsible Summicron 5cm F2, wide-open on the M2:
Type 1 Rigid Summicron 5cm F2, wide-open on the M3:
picture.php
Summar 5cm F2, on the Leica IIIa. Wide-open or close to it.
I sold one Summitar, traded the other for a Thorium Summicron.
