M8 Top Cover uncapping
_goodtimez
12:09 PM
Hi All,
I am interested to know if any of you has removed the Top Cover from an M8, or if you have a link to show how to do this.
I do have the capability to make my own tools for that (like the special pliers for the M6 top removal).
I will receive soon the dunken M8 from my sister and I would just like to start with the top off, to see if there is any corrosion at that level and eventually clean the inside of the VF glass.
Thanks
http://www.l-camera-forum.com/leica-forum/leica-m8-forum/73166-how-unscrew-viewfinder-lense-if-its.html
To remove the top, you'll need a Phillips P000 screwdriver and a long P00 one, 75mm.
1. Remove the base, battery and memory card.
2. Use the P000 screwdriver to remove the 5 screws; these are tight and you should press into the screw when first loosening them to stop the head slipping.
3. Remove the plastic plate; look inside the battery compartment and remove the screw nearest the end of the camera using the P00 screwdriver, this screw will come out; you'll need the tweezers to put it back.
4. At the other end, look for the hole in the motor baseplate. Insert the screwdriver and feel for the screwhead; this screw is captive and will not come out.
5. Ground yourself to a water pipe or electrical earth to avoid any static discharge
5. Ease the top off and release the flex-print by lifting the plastic latches and gently pulling it out; avoid touching any electrical contacts.
You can then clean up, avoid at all costs getting your finger prints on the inside of the rangefinder windows and the rangefinder components - think about wearing silicone gloves.
