Fujitsu
Which of these would you recommend for the GF1?
go with a pre aspherical 35mm Summilux
of the 2, i would go for the 40.
but really, the difference between the 2 is negligible.
If you intend to get a 50mm next time a 35mm would be better
For use on a GF-1 I don't understand why you would sweat and spend a lot of money on a modern manual-focusing over-sized lens with reputedly less than stellar bokeh? All you're buying is the f/1.4 aperture and not much else with those two.
If you want the soft shallow depth of field with great bokeh look then just go a bit longer and get a user 50/1.5 Summarit or some other vintage speed normal. Then you'd actually get something interesting in your photos, the lens would have some character and generate conversation with your subjects, and it would be less expensive....
