Thank you. I will look into this one.If you look for a fast and sharp 35 and the size and weight of the ZM 35/1.4 are not a problem, why not choosing this lens? Too expensive? If so, did you think of the Nokton 35/1.5 asph? Similar IQ and size as the current Summicron with the added benefit of f/1.5 and a 0.5m MFD it is perhaps the best modern 35/1.4 (35/1.5) available below 1,000 GBP. Couple of snaps at f/1.5 and f/2.8 attached.
I will check these out. They look remarkably small.This has worked well for me.
Voigtlander 35mm f/1.4 Version II Nokton Classic Leica M Mount
MC Multi Coated
The CV 35mm f/1.4 Nokton II is about the same size as the pre-Asph Summilux. And, compared to the Summilux, it's probably a better performer as to sharpness at its wider apertures. The first version of this lens (which I owned for a short time) had fucus shift issues that were corrected in the 2nd version. It's likely a good option for you. How does it match up to the Distagon? – I can’t comment. …I will check these out. They look remarkably small.
The Nokton 35mm 1.4 is a very good lens at a modest price
(M4, 35mm Nokton SC)
This one is definitely on my shortlist.
That´s my go-to lens on my .72 MP. Perfect lens, congrats to you!I found a 35mm Summicron in excellent condition (1st version ASPH)
