sanmich
Where do people come up with statements like F2.0 barely useable??
My experience is more in agreement with feriders.
+1 here
the DR cron has the highest center resolution of my 50's bunch.
The collapsible is no slouch either.
Also the classic Elmar can not be collapsed into some bodies such as the Bessa R*, while the Summicron can.
The focus will move while adjusting the f-stop, so I tend to keep one finger on the lock/focus tab, also I find the hood obscures the Ap ring a bit. I have both the 2.8 and 3.5 M-Elmar and think the 3.5 is a cut above the 2.8.
Well, I'd like to see more examples of images made by the lenses mentioned.
I have 5 Collapsible Summicrons. The two 13x's are better that the two Thorium Summicrons, and better than the SN115xxxx lens.
Also have a Type I and Type II Rigid 50/2 Summicrons, total of Seven 50/2 Summicrons. I just shimmed a 90/2 Summicron for the M8. It was off a bit on my cameras. Glad the optics module unscrews so easily.
You can get both an M mount 2.8 and 3.5 Elmar, they have the apertures on a ring like a Summitar etc. Of the Two I believe the 3.5 is not so common.Isn't the 50/3.5 Elmar a whole different animal regarding aperture setting? I thought that lens has a little aperture tab on the front face of the lens that you can't even reach with a hood mounted
Isn't the 50/3.5 Elmar a whole different animal regarding aperture setting? I thought that lens has a little aperture tab on the front face of the lens that you can't even reach with a hood mounted....
