One to fit Nikon/Contax cameras?
It will fit a Contax camera, but won't focus properly. That's why its an "S" lens (for Nikon S-mount only) rather than an "SC" lens(for both Nikon S-mount and Contax) like the 35/2.5 Skopar and wider.
Stephen Gandy said it was added because of getting a more compact lens. Makes sense.It's mysterious to me why a modest-speed f/2.5 50mm would "need" seven elements, but surely that adds to the heft and feel of solidity.
Yes, that makes sense, as at 33mm long it's shorter than either the 50 Heliar Classic or the Planar or C-Sonnar for instance. And yet it's virtually identical in size to the new Leica 50/2.5 Summarit which has 6 elements in 4 groups.Stephen Gandy said it was added because of getting a more compact lens. Makes sense.
Really? That would make it quite small indeed! And yes, either the 21 or 28 would round out the wide end... 🙂
Don't suppose you have a picture of all three, lined up?
I don't use to make pictures of my gear 😀 but they have the same size +/- 2mm 😀 , Really small for a 50 mm 🙂
the 21 and 35 have the same barrel
I knew the 35 and 25 (21?) shared the same barrel which is great. Good to hear the 50 isn't much bigger as well. Thanks!
