Leica LTM Elmar 9cm f4
lxmike
M2 fan.
7:57 PM
Hi how do people find this lens, I've been offered one, (a nice clean example) circa 1949, for £60, I intend to use it on my Canon P
regards Mick
Mine's about 1951-2-3, and I like it especially the size. It is sharp and not too much bigger than a normal lens.
Mine is from 1954. Perfect glass, I cleaned some haze out of it myself.
On the M8, wide-open.
picture.php
picture.php
On the M3, Fujicolor 200, 1/15th hand-held.
picture.php
Classic Leica look to the images. Sharp from 5.6 on. You will need a lens shade.
If you don`t carry one in your pocket, you are just not a Leica guy.
How difficult is it to find the hood for the elmar
look for the fikus at Ebay, it is really cheap
I have the uncoated 1933 version of the lens. Optics were not clear when I bought it, but it is one of the lenses that is very easy to clean yourself externally as well as internally. The lens is quite sharp but as all pre-WWII lenses, lacks contrast.
The hood is made to be used for 5, 9 and 13,5 cm lenses.
john mentioned that it is not much bigger than a normal lens, does anyone have a pick of a 9cm next to a 'normal lens'
regards Mick
Thanks batterytype, I must admit I have just, (because of this thread too), bought a 9cm f4 Elmar to use on my Canon P.
regards Mike
The collapsible will not collapse on a Canon P, would hit the light baffles. Even if someone converted one to LTM, it is an M-Mount lens. I recently worked on an M-Mount lens that was converted to LTM.
The Rigid is small and light, but larger than a 50mm RF lens.
I have one of each.
Many thanks Brian, I have just bought the rigid variant, would post some photos, but do not know how to
^ Two ways:
As attachment (under "Additional options") -- downsides are size limit, only logged-on users can see it, automatically deleted after two years (I think)
As URL: If your photo is on the web (RFF gallery, Flickr, ...), you can use the little "sunset" icon and paste a link to your picture into the dialog box that appears.
It's longer but very small in diameter, about the same as that of a Summar. @ Lxmike: if you need hood give Mwclassic a call, pretty sure they have one.
this is the lens I have just bought for £62
When you get her check the serial number on the optical part with the focusing body.
I had a somewhat later one, in M mount but she was fun. I got her as part of a carry everywhere kit that I built for my M4-P when my M6 became my primary shooter. She fit in my pocket when I was walking around the Village late at night.
Enjoy her, she is a wonderful companion that will serve you well for many years.
B2 (;->
lxmike -- that lens is definitely coated, both from the look of the reflections, and from the serial number being above 600000.
If there's no haze in it, it should be up to snuff.
Not really particularly sharp wide open, but pleasant. With coating, will have some contrast, but not a lot.
