Elmar 9cm f4
lxmike -- that lens is definitely coated, both from the look of the reflections, and from the serial number being above 600000.
If there's no haze in it, it should be up to snuff.
Not really particularly sharp wide open, but pleasant. With coating, will have some contrast, but not a lot.
Very pleasant wide open, this is not a great shot, because I used 1/15 second shutter but it is still something I like:
That is a very late issue Black Elmar 9cm F4! I had one in chrome just like it, Sn a bit higher. I think yours is a WW-II serial number.
(Edit: Looks like this one is post WW-II, from 1947)
Yes, it was a good price. Coated, Black lenses are "uncommon". The price paid was good for an Elmar 9cm F4 in general. It is an under-rated classic.
Collapsible Elmar 90
Was there ever such a thing as a collapsible 90mm Elmar in threadmount? The only ones I have seen were for the M's.
Dez
Well Brain and Tom, I'm more than happy with by 9cm
Elmar, (which arrived today), the glass is indeed clear and coated and I'm impressed with the build quality. A hood has to be sourced next, a Fikus, (that way I can use it on my 5cm Elmar as well.
regards Mike
Before you buy that FIKUS
I would suggest that you look into a 34mm screw-in hood for the early 1930s Elmar 9cm f/4. The one I purchased costs under $10 from "Jackthehat" in the UK. It doesn't have the "Leitz" label on it, but it does the job. A 37mm pinch cap fits the inside diameter as a lens cap.
Jack the Hat Shipping reduced to 3 Pounds Sterling
Hello,
After I posted, I received word from Jack the Hat that they can send this hood for 3 Pounds Sterling (not 10) to RFF members. Just mention this to them. They will be revising the shipping cost on the hood in their web site eventually.
3 pounds is $4.39 at today's exchange rate.
I don't work for them. I merely ordered from them on a chance that it might work, and indeed it did.
Alas, I don't have any good answer to the 5cm Elmar hood. FISON prices are obscene lately. I'm trying to source a 36mm slip-on hood for my Industar-50, which is the Ukrainian copy of the Elmar. Some of the Industars do have a thread on the inside of the knurled outer ring, but my 1961 vintage lens is completely smooth there.
I hate to buy a hood that costs multiples of what the actual lens costs - seems perverse!
I might just roll up some cardboard and paint it black as a last ditch measure.
