filter on 50mm lens for mamiya 7?
2:10 PM
toronto, kingston, vancouver
hello there,
i want to get a good quality skylight filter for the 50mm lens for my mamiya 7. it feels like ive been gambling the past two years, with dropping it, or with getting dirt on the lens. plus with a filter i would likely leave the lens cap off, preventing wasted shots. :bang:
however, i am wondering if a regular filter -- say a standard b+w filter with brass ring -- might cause vignetting? should i go for one of b+w's slim models instead?
thanks for feedback...
I only have a Hoya HMC 81B (chrome on overcast days) and a B&W K2 (yellow). They are both standard filters. Neither vignettes on the 50mm lens on my Mamiya 7. .
regular filter is fine
I use a normal filter on both the 50mm and 43mm on my Mamiya 7. Slim not needed, I'd say.
hi,
i have a related question: does anyone have experience with using a 62mm filter + step-down ring on the Mamiya7 50 mm lens (which has a 67mm filter thread) - do i have to expect vignetting or would that combination be still OK?
thanks!
hi,
thanks!
I think that would be pushing your luck (sorry no experience on this particular combination). It's not only the reduced diameter but also the added thickness with the step-down ring.
