Mister E
Ampguy, I'm glad I'm not the only one on here who understands!
This is incorrect. DoF doesn't change based on sensor size, but the working distance for a given focal length to get the same perspective does. For a 1.5x sensor you would have to stand 1.5x further away to achieve the same framing. Because you are 1.5x further away you will have MORE depth of field. This has nothing to do with the magnification for prints, etc. The hyperfocal markings on the lens still apply to crop sensors because of this. A 50/1.4 Lux has the same DoF at 10' on the M8, M9 and m4/3.
Makten needs to show up in here. He is DoF explainer number one fan.
Same lens, same photons, same medium, same angles of rays, same lens to sensor medium distances, same DOF.
Actually, I am perfectly right. You are simply adding arbitrary condition such as equal field of view. This is just about the DoF scales on a 35mm lens. Step back and the same adjustment would have to be made.
And different display size magnifications...
Your display size and magnification is completely irrelevant.
How can things like print size and viewing distance affect DOF when these DOF devices don't even consider them? The answer is rather simple. The people who created these devices, as well as the people that manufacture cameras and lenses, make assumptions when they evaluate DOF. A typical assumption for a full-frame digital camera or a 35mm film camera is that the photographer will make an 8"x 10" inch print that will be viewed at about 12".
Is that a 35mm FoV or a 35mm lens?From this resource, if using a 35mm focal length lens:
M8 @ f4 focused at 10' will have a DoF 4.77' (8.15'~12.9');
M7 @ f4 focused at 10' will have a DoF 6.47' (7.72'~14.2').
M8 @ f8 focused at 10' will have a DoF 11.42' (6.88'~18.3');
M7 @ f8 focused at 10' will have a DoF 18.10' (6.29'~24.4').
Infer what you will.
Well guys. I win. Here is an image photographed with the same lens, same aperture, at the same distance. The only difference is sensor size. the image on the left has more depth of field than the image on the right.
http://www.rangefinderforum.com/photopost/uploads/3853/dof.jpg
Can we see the Leica quote, Ted ?
It's very simple really:
1) take a "bokeh shot" with background lights on film; scan in; print it on 5x7.
2) take the scan into Photoshop; crop it by factor 1.3; enlarge it and print it out on 5x7.
The OOF circles of 2) will be 1.3x larger than 1). Less DOF in the cropped picture.
2) is equivalent to taking the same picture as 1) on the M8, at the same focus distance.. Ergo, the DOF marks on the lens mean something different for MP vs. M8.
DOF is defined for fixed print size and viewing distance.
Here is a longer explanation (scroll towards the end):
http://www.luminous-landscape.com/essays/Leica-M8-Perspective.shtml
Roland.
Jeff, "object size occupying the same portion of the frame" is not having the same magnification. You are simply fixing field of view, which is not what we are talking about.
You "expert" source that DoF scales are wrong is wrong. DoF scales is only a guide. You can change the criteria for sharpness if you are not satisfied with it. However, it still does not change what DoF is nor the conditions that affect it. Having zone focused with modern cameras, their DoF scales are very good.
I was wandering in the darkness on this subject until I recently saw the light. Ferider says it right in post #6.
If you don't believe that a 50mm lens at f/2 focused at 1 meter has different DOF on an M9 vs. M8 vs. EP-1, just trot over to http://www.dofmaster.com/dofjs.html, input the data and see for yourself.
