HP5 Plus
koniczech
10:34 PM
Behind my GSN
Hi.
Since scanning takes a while, I thought I'd just share my thoughts. Ilford HP5 Plus amazes me. Despite the fact that I had to wait 3*24*1hour, the results are worth every minute. While I'll give some kudos to the Yashica GSN, my older C41 b&w don't look half as sharp, etc.
Photos to come...
koniczech
p.s. Post yours, as this is an HPS+ appreciation thread!
Hp5 @ 1600 in Xtol 1:1 looks amazing. I printed some last night and wow that grain is brilliant!
Somebody please reassure me that it looks just as good pushed in Hc110.
The grain is going to be more aggressive in HC 110. Xtol has a slight "mushing" effect on grain and smoother tones. The HC 110 more resembles something done in Rodinal 1:50 or 1:100.
I always liked this one.... It is one of the negatives that I printed last night. I tried scanning the print on a cheap office printer but it came out terrible so here is an old negative scan.
All of my other scans are on a hard drive which I have lost the cable for.
Generally my results look a lot like this fellow's work, http://www.flickr.com/photos/91744974@N00/2328029840
If I shot HP5+ 400 at 100, then had it processed as 100 and pulled 3 stops, how would the contrast look? I'm thinking of trying it, because I like high contrast in my bw images.
I would think you might want to push to increase contrast.
I'm not a huge fan of HP5 in 35mm as I find it a little flat unless pushed a stop or two but I shot some in 4x5 recently and was impressed with the tonality.
Ah, always a pleasure to praise an old friend!
I've been an HP junkie for a quarter of a century--an occasional brick of Tri-X or Neopan only made the addiction worse. Curve, tones, grain--de gustibus non disputandum... But some things I have verified "scientifcally" (or at least "empirically") over and over again: the most robust base and the hardest emulsion I've ever seen, almost impossible to damage in processing; density visually higher than any other film. And then, it's the only film I've never seen an air bubble on!
Here, in DD-X...
