thrice
Ahhh yes! No need to worry if you use film, as it appears the coincidence of the mount screw and the lens screw is required for the light to squeeze through sufficiently.
To bad it happened on my Ikon too, so it is not a Leica problem as much as I'd Leica it to be.This isn't a Zeiss PR problem. It's an issue caused by Leica's relocation of the screws that hold the lens mount to the body.
Again, certainly it wasn't Zeiss' intention to make their lenses incompatible with Leica. That doesn't serve their goal of selling lenses. If they wanted to create incompatibility, they would have simply revived the old Zeiss Ikon Contax mount.
However, it does point to the real-world difficulties of being unable to account for what other companies will do in the future and that you have to be ready to address those problems.
To reply to others, no, obviously, I don't have an M8 or M9 and won't in the near future, barring a lottery win. But that's not the point, is it?
For anyone who troubleshoots problems, the first thing that you have to do is to reproduce the problem so that you can properly diagnose it. So anyone who thinks that Zeiss should immediately issue a statement without properly investigating it first is simply wrong.
Doesn't matter if it's a car, software, cooking or a camera. The process should always be the same. Reproduce the problem. Diagnose it. Solve it. Hopefully, they're in the "solving it" phase.
That screw is in relatively the same place on my Ikon, M2, M6 and from the looks of it M8/9.Note that Leica has deliberately changed the position of this screw with the introduction of the M8. See how it looks on the M6, which is the same on all other Ms before the M8:
With that kind of arrangement it should work fine; with the redesigned M8 mount you get the screw arrangement that leads to the light leak you describe.
Makes you wonder why they put the screw on the camera right where it is. They probably had a good engineering reason to do so, with the added side effect that Leica lens competitor Zeiss now has a PR problem and likely has to change the bayonet on all their lenses.
I'm curious if Zeiss ever followed up with anyone on this issue - it's been long enough by now, certainly...
Mister E, does your 25/2.8 have the newer mount with the groove for coding?
Turn the camera up sid e down and see if the reflection moves. Then tape the mount/flange connection and then the whole rest of the lens. You should be able to isolate it.
No idea, I sold it a few weeks ago.
Great, I had shot with the lens and had no issues with it so I'm not surprised to hear it is working well for you, but it still makes me happy 😀! Thanks again!I can confirm that it has the old mount without the groove for coding.
