bennyng
Benny Ng
Dan, you're right that's not very long, but companies have been making m-mount lenses for 50 years without issue. I wonder if this is a ZM only issue or if it is an issue with other cosina lenses. I've had the ZM 18, 21/4.5, 25/2.8, 28/2.8 and 50/2. The 21/4.5 was the only one where I saw any issues.
Nate,
I see that you aren't going to wait for a solution from Zeiss and have moved on from Zeiss products, or at least the lenses. Funnily, I was just about to pick up a set of Zeiss lenses, pretty much similar to the focal lengths you have above except I'll replace the 50 with a 35. I suppose now I'll have to reconsider.
I wonder if Voigtlander lenses have the same problems. Perhaps somebody can compare the lens mount with the Zeiss ones if they have access to both lens mounts.
p.s. Many thanks for the great detective work and trouble shooting from Daniel (thrice) and Thomas (trisberg)! Well done!
