kshapero
South Florida Man
If 35mm lenses give a wide field of view than isn't a 28mm lens better?🙄
what does this even mean?
you need a 28mm. you cannot live without one. you are getting sleepy...so sleepy...
You make it sound like a joke. Never ridicule the 28mm focal length.
In all seriousness - a 28 on a Leica is very close to what I consider photography heaven, one should at least give it a shot.
martin
Better for what?
I find the 35mm focal length better than the 28mm (on a 35mm camera) for “street shooting” because the 28mm give me more distortion than I want.
I find my 35mm focal length better than my 28mm (on a 35mm camera) for shooting in dim light because my 35mm is an f/1.4 while my fastest 28mm is an f/2.8.
I find the 35mm focal length better when I am carrying 85mm and 180mm lenses.
I find the 28mm focal length better when I am carrying 50mm and 105mm lenses.
I find my 28mm focal length better than my 35mm (on a 35mm camera) for landscapes and architectural because I usually need the wider coverage, plus, my 28mm f/4 is a perspective control lens while my 35mm is not.
I find the 28mm focal length better (on a 35mm camera) for macro shots when mounted in reverse position on a bellow unit because I can get higher reproduction ratios than I can with the 35mm.
I find the 28mm focal length better than the 35mm (on a 35mm camera) when shooting in tight quarters.
I find my 28mm focal length better than my 35mm (on a 35mm camera) .... because..... my 28mm f/4 is a perspective control lens while my 35mm is not.
By this logic, the best lens available is the 12mm Voigtländer.
