I think the question is not so much about 'need' but more so about 'want'. Considering your lust for 35mm, if you don't 'need' the speed, which it seems you don't then take a look at the Biogon-C instead.
Vick, R's idea is not bad one...the summilux 35 asph is a very fine lens, but it is the second best 35 I have used. If i am not mistaken, though, you already have the best 35 -- the 2005 re-issue of the S-mount W-Nikkor C 35/1,8? Perhaps consider getting your copy converted to M-mount....it would cost than a zm35/2 and way less than a summilux asph 35 😉 That's if it is not heretical to tamper with mounts according to your photographic morals!?
