Armoured
While both of these are brilliant (altho haven't used the lens on the C220 that you say it has), you may also want to consider a non-interchangeable lens TLR, like a Rolleicord or the innumerable derivatives. They're a LOT smaller and also give great results.
You didn't say much about what you're using it for, so that should drive the decision. But for a starter medium format kit, I like the smaller ones better for most uses.
Or to put it more simply: you may find the C330 about as handholdable as the RB/RZs in terms of weight, although much less lens slap. Rolleicord-class is closer in size to a medium-sized 35mm SLR (maybe a large one). It's a really big difference, in most cases, the difference between taking it with you or leaving it on the shelf.
