MarkWalberg
My son got one of these a year or two ago, C22 I think. He's been using it to take pictures of humming birds, and he's got some pretty ones.
I think you got me confused with Irving Penn..I used a disc brake rotor to make my floor pod. Penn used a 8" steel disc with holes drilled in it for 3 bolts to level it. As I'm even cheaper than Calzone, I used the disc brake rotor because it was free. A brake drum is at least 20+ pounds !Minolta Autocord Low Tripod by Nokton48, on Flickr
MFM,
I made this one and it works OK. I believe Penn had a metal auto brake drum as a base, then had welded a bolt onto it. Then he threaded the good Leitz Tiltall Head onto the brake drum. Talk about SOLID. Must have weighed a TON
Also MFM,
I also ordered 20 rolls of 120 Kentmere from B&H to try, running out of 120 HP5+.
Not the first camera I'd think of to photograph those speedy little critters, but good for him! I imagine he must be using one of the prism finders?My son got one of these a year or two ago, C22 I think. He's been using it to take pictures of humming birds, and he's got some pretty ones.
C22 55mm Mamiya 120 Delta 100 by Nokton48, on FlickrI think he doesn't use a finder at all. He sets up the camera and fires the shutter when the bird is in front of the lens.Not the first camera I'd think of to photograph those speedy little critters, but good for him! I imagine he must be using one of the prism finders?
Minoltaflex XX SRT Flash YG by Nokton48, on FlickrI never thought of using my Hasselblad stove pipe on my Autocord! thanksMinoltaflex XX SRT Flash YG by Nokton48, on Flickr
This is the Minolta SRT Electroflash 1, hooked up to a Minolta Autocord. The Stovepipe is Hasselblad and works perfectly. It's FUN to use, I've been popping off shots, on Eastman XX 5222 120 film. Really enjoying using it, it carries easily and works without fuss. Good for incognito photography.
MFM,
Ready to start shooting my twenty rolls of Kentmere 400. Hopefully it will stand up to HP5+ when shooting 120 roll.
Very nice setup, but hardly what I would choose to shoot incognito! I like using my big old Mamiya TLRs (and Big Bertha Bronica S2A, and monster Horseman 985, etc.) when I want to be seen. The choice of using a big, weird camera is integral to my shooting style when interacting with strangers. Generally, the more funky, old, and chrome-covered a camera, the more people relax and understand that I'm working at making an image of them. It seems to foster an understanding of mutual respect.Minoltaflex XX SRT Flash YG by Nokton48, on Flickr
MFM,
I did not, and just Googled it. Seems they never made it past prototype stage, and those are stashed away in German museums. I couldn't find a picture, either. So, is it possible to have GAS for something that never went into production? Because, sight unseen, I want one! 😀9x9cm on 9x12cm or 4x5 is my go-to. Did you know Rollei made a 9x9cm Twin Lens?
Good luck finding 9cm roll film (and putting 6cm in upside down does not work, and no, I did not try it)! If a 6 were a 9!I did not, and just Googled it. Seems they never made it past prototype stage, and those are stashed away in German museums. I couldn't find a picture, either. So, is it possible to have GAS for something that never went into production? Because, sight unseen, I want one! 😀
Makiflex JLane 9x12 Glass Plate EI 1 Key Day by Nokton48, on Flickr
Makiflex 4x5 Shanghai Octobox 150 F16 D23 by Nokton48, on Flickr
C22 No 2 135mm New Leitz Tiltall Hacked Leitz Ball Head by Nokton48, on FlickrA lovely portrait! 😉C22 No 2 135mm New Leitz Tiltall Hacked Leitz Ball Head by Nokton48, on Flickr
Mamiya C22 Body #2 with 135mm Blue Dot Yellow Filters Paramender. Mounted on new to me Leitz Tiltall heavily modified. Regular column replaced with modern black one with Leitz Ball Head neatly permanently attached. This new Ball Head (same as on my Leitz Tabletop Tripod) works great on the original Tiltall and a Japanese Quick Mount, which also works great with the Paramender. This weighs little enough that I can carry it around with one hand without straining. And it is rock solid Leica Quality. Broncolor Octobox 150 left, 4x6 foamcore right. Sony Nex-7 with Zeiss Touit Makro Planar 2.8/50. Painted background by David Maheu "Tiim Kelly Gold Plaster".
Mamyflex 180mm Hartblei Stovepipe Paramender StarD by Nokton48, on Flickr
