250swb
Details of the Thumbie can be found here (its just a page to put the instructions on not a 'blog')
http://stevesblogofeverything.blogspot.com/
The tape is designed to hold trim onto cars, so it is long lasting, holds up to heat and cold, and doesn't damage paintwork. The contact patch is such that if the Thumbie is fitted properly it won't fall off, the pressure is evenly distributed in more than one direction. But it can be easily removed, the old tape just rolls up under thumb pressure.
As its not a full time job they are available on ebay on a regular basis, but not in vast quantities. Or you could try contacting the errrm head man direct via the email on the instructions site.
