al1966
Feed Your Head
I used D76 or its cousin Ilfords ID11 for a long time I tried others but I just keep coming back. I am considering a different developer for the fp4 I have just bought and will be open to suggestions.
			XTOL is supposed to be the new age D76.
How is that so?
It was designed to give similar tonality to D-76 with slightly finer grain, less toxicity, and slightly higher (1/3 stop was claimed if I remember right) effective film speed. Like D-76 it can be used straight or diluted 1+1. Early instructions from Kodak included instructions for dilutions of 1+2 and 1+3 but those were dropped because those dilutions often failed due to the user using too small a tank with them (there wasn't enough of the stock solution in the diluted working solution to fully develop film unless a larger tank with fewer films was used).
XTOL
Because, because, because, because, because;
Because of the wonderful things it does.
Well, yes, I am aware of that. What I don't understand is how XTOL is "New Age".
I believe that calling a chemical 'less toxic' indicates that using it will reduce its impact on the environment.
From the Wikipedia article you referenced: "New Agers advocate living in a simple and sustainable manner to reduce humanity's impact on the natural resources of Earth;"
Finer grain and higher speeds seem to appeal to desires. Not very New Agey.
Ahhhhhh. Well, that certainly had flown over my head. Duh. Got it. Mah bad.
I agree Chris. For the one doing the developing, personal protective equipment is a must, as their exposure is thousands of times greater than is environmental exposure. A dust mask and nitrile gloves are essential. Chemical splash goggles (ANSI Z-81 compliant) should be used with highly alkaline solutions such as Rodinal. I always tell my (chemistry) students the first time they use it, "If you get sodium hydroxide in your eyes, take a quick look around, because that will be the last thing you see."
Speaking of Rodinal, I cringe at it's popularity. The main ingredients are sodium hydroxide and hydroxyaniline. The former, sodium hydroxide is a contact hazard - it'll cause your skin to crack and bleed, especially with multiple exposure. It feels like soap on your skin, because it is dissolving the fatty acids out of your cells, and making soap out of you.
Hydroxyaniline (aka para-amino phenol) is toxic in very small doses, and can be absorbed through the skin. The symptoms of a small dose are nausea, and loss of fluids. A large dose is usually fatal. It biodegrades very slowly, and is toxic to aquatic animals as well as the microorganisms that are used to break down sewage in waste treatment plants. Nasty, nasty stuff.
Rodinal's concentrate is quite toxic, but diluted 1+50 or more, the Potassium Hydroxide (the packaged version switched to Potassium Hydroxide a very long time ago) is no longer that dangerous. Like acids, strong alkalines weaken with dilution. ...
... I did not know that the developing agent was that toxic in small doses! I've never heard it called Hydroxyaniline. Isn't the actual chemical name 1,4-diaminobenzene hydrochloride ? Almost all developers are benzene based. Metol, Hydroquinone, Phenidone, and Pyrogallol all are!
