Smallest M Mount Lenses
there is a M mount version of the Pentax 43mm Ltd. I don't exactly know how it compares with other mentioned here, but it can'r be that big
no way is the UC smaller than the Canon 35/2. I refuse to believe it.
You're right... that's my mistake.
Rollei Sonnar 40/2.8 in LTM: shares the same barrel and filter size as the dimunitive CV 28/3.5. Would make a killer pair for daytime shooting...
The Pentax 43/1.9 in LTM (not M mount) is actually big for an RF lens, especially for a "Barnack" LTM body (the special 43mm viewfinder is also big). It's about the same size as a modern 50/2 Summicron (which I don't have but have seen) or M-Hexanon (which I do have). Definitely not in the "pancake" category.
Some photos in this old thread: http://www.rangefinderforum.com/forums/showthread.php?p=1260188
Someone mentioned the 28 Hektor, truly compact, but image quality is not that great and it flares wildly. The Summaron 28f5.6 is a better choice and truly compact - even smaller than a 35f3.5 Summaron. It is also a very high resolving lens - though the contrast is flat - very flat. I used to use it with PanF and Tech Pan to boost it.
Another compact lens is the Ricoh GR 21f3.5 in screw mount. On a Bessa R4 you dont need a finder so it becomes a truly "compact" wide. The ergonomics are OK, focussing tab and small lever for the aperture ring. Always takes me a while to "rethink" that. Keep trying to focus with the aperture ring. I just put it on my R4M - but crappy weather prevents wandering out with it today. The hood is massive and heavy too.
The Ricoh 28 is also very compact - but I found mine to be a bit flare-prone.
The UC-Hex has a wider front rim than the Canon 35/2 (43mm vs 40mm) but I bet it's shorter. BTW, the Nikkor 35/1.8 LTM is approximately the same size as the UC-Hex.
The Canon 28/2.8 has to be the smallest in its class, with the M-Rokkor 28/2.8 following it.
Ari
Hey John,
As you know I own a 28/3.5 Canon Serenar. Kinda works great for me since I basically only use it at F5.6 or F8.0 where its sharp enough for me.
At the next NYC Meet-Up I'll bring my 35/1.8 Nikkor LTM.
Also would say that Andre's 35/2.8 Summaron is a cute small lens.
Cal
FWIW, I just saw one on the 'bay for US$1800, with finder. Those were selling for under US$600 (more like $750 by today's exchange rate) in Tokyo just last year, only a little more in North America.
