Chriscrawfordphoto
Real Men Shoot Film.
So since most people are not capable of reading instructions carefully enough 1:2 and 1:3 dilutions are something NOBODY should use?
Kodak made that decision because they got such an overwhelming number of complaints about Xtol 'dying' and they were getting bad press in the darkroom oriented magazines of the time. The cause of the problem was partly the manufacturing problem I mentioned in my earlier post, but that was fixed early on. The use of high dilutions in small tanks was the biggest cause of the problems people had with Xtol, and even today, as Venchka references in his original post, Xtol has a bad reputation that it doesn't deserve because it simply isn't strong enough to handle much dilution in normal use under the conditions that most users will use it in.
Having tested the higher dilutions, used correctly, back when Xtol first came out, I cannot see any advantage to them over the 1+1 dilution. To me, it is just making life difficult on yourself for no reason.
