I also had an R1 briefly as well. Lovely to look at, but mine had a dead LED, and the autowind sounded like a cat in a meat grinder.I briefly had a Ricoh R1 (not GR1!) and it was utter rubbish - it went back for a refund. Massive distortion, overexposure, nasty to use.
Does anyone else like APS? I've several that can hold their own against other, bigger ones. The Contax Tix springs to mind immediately but there are others by Konica (Z2 and Z3) and Kodak (T550) that no one seems to want and so you can pick them up for pennies...
And, back to 35mm, has any one a Yashica Minitec super? I ask as I've one in the heap I've not tested. And this seems a good thread to pick up opinions of these neglected but usually pretty good P&S's.
My latest addition. I've already loaded it with film. Let's see how it compare against the T-4.
I thought the Vivitar was broken, it would load film but the flash would not charge, and the shutter would not fire. But then I remembered a thing called "dry capacitor syndrome", and let the camera sit with batteries in and the clamshell open for several hours, and it suddenly sprang to life. The pop-up flash is not spring loaded, but motor driven. Very robotic, but quite noisy. The auto-wind and shutter are very quiet, though, and focus seems fast.I like that Vivitar. Very nice. I've got a broken Vivitar 35EM which would be a hell of a camera if it was working. unfortunately they seem to always show up broke. Metal bodied with a swing lever that brings the lens out and back in. Displays the aperture and shutter speed in the display. When you can find a working example that is 🙂
