is there an LTM 50 that does not intrude
paulfish4570
8:57 AM
Lapine, in deep south Alabama
into the viewfinder of my IIIf?
my 50/2.5 color skopar intrudes enough to make careful framing on a static shot a bit of a guessing game. i suppose a separate viewfinder would take care of this also but that would take away some the compactness that makes a barnack so fun to use.
I think the 5cm f3.5 Elmar is about as small it gets Paul ... I have one that I use on my Leica ll occasionally. It was a 'red scale' that I picked up off ebay for $120.00 because it had been dropped and the front bezel was a little bent ... no big deal it straightened easily.
They are a very good lens ... though the aperture adjustment is a little tedious.
The previously mentioned Elmar is smaller in diameter than the CV50f2.5 but it sticks out farther so it's a wash. There is nothing more compact than the lens you already have.
A vented hood helps somewhat. Since the lens only intrudes on the center of the view finder, it helps to frame based on the bottom corners.
Get one of these with one of these.
RATS! The Internet Police snatched the photo. It was a Canon IVS2 & Canon 50mm/1.8 lens.
...and maybe one of these.
Let some light in! 😎
I went through this exercise 5 or 6 years ago. The Canon 50/1.5 intruded less than the 50/1.8 Chrome. I also have the 50/3.5 Elmar. Of course COLLAPSED the Elmar is shorter. But not when extended. The Jupiter-3 is slightly longer than the Canon.
The rigid Industar-22 might fit the bill. I've never seen one in the "flesh" (aluminum), though. Can anybody confirm?
Bit of an academic answer, anyway, as it's rare and seems to be fetching collector prices.
I have a very nice 35mm viewfinder. Alas, it comes in the original case along with the Canon 35mm/2.8 lens. I absolutely GUARANTEE that tiny gem of a lens won't protude into the finder. At least not with the original hood (also in the case) removed.
