Trius
Waiting on Maitani
And my AR 40/1.8Wow, I'm just imagining if I can do this with my Konica Hexanon AR 35/2.
Too bad no one sells a Konica AR to Leica M adapter 🙁
Oh ... I'd have to buy an M? Sigh.
As for the K to Leica adapter, there are much cheaper versions available ... The Novoflex one is much more pricey.
Phil Forrest
Interesting, Michael. Anybody can show a photo of the rear of an M42 copy of the Takumar ? (to use one of the Russian M42/LTM adapters)
Roland.
Thanks for the photos, BT. The rear element ring doesn't seem as easily accessible as in the Pentax bayonet mount lens, I leave modifying this one for somebody else to try.
Raid, and others, the only options you have is a Novoflex adapter for a general M conversion (bringing up 50mm framelines), or the Kipon Pentax/M adapter, if you are OK with 35mm framelines (for example, if you want to use the lens on an M3).
Roland.
So this is the M(K-Mount) version of the lens not the M42 version as I originally thought.
I have 2 of the M42 lenses here. I wonder if it is the same mod for the screw mount lens.
