canon 50 1.5 on M
vic225
10:07 PM
does anyone have a problem with the RF coupling when used on the M camera? I cant focus to infinity... there's still a little bit for the patch to go in order for it to line up..
Get someone with a micrometer to measure the thickness of the LTM-to-M adapter. If it is not exactly 1mm thick, it is defective, and the cause of your problem. Your symptom would be caused if it was a little thicker than 1mm.
