Printer recommendation please - epson r3000 or 3880
david.elliott
6:09 PM
Washington DC
Hello all,
The R3000 seems to be about $650 now and the 3880 is going for $900.
The R3000 is the newer product, but the 3880 comes with much more ink.
I plan to print both color and black and white 8x10 and maybe slightly larger.
Which printer would you recommend, and why?
Thank you for your assistance!
Best regards,
David
Haven't tried both and I know this doesn't help much but I have a 3000 and it is fantastic, Don't know what else I could ask for in a printer except maybe to print bigger (13x19's don't look as big once they're on the wall). I would say it depends how much you plan to print each year. Bigger carts are a better deal if you're going to use them but if you won't print enough to use up all the ink than I believe they dry up over time.
David,
I have the Epson 3800 - the R3000 wasn't out when I purchased the 3800 some 3 years ago now I believe - I have yet to change a cartridge and the B&W prints (and colour for that matter) are sublime. My ink is currently "low" but it's only the "photo black" and, I think, the "light light black".
If you're not printing a huge amount on a regular basis (which would prompt me to suggest the 4800/4900 series) then, as someone who's used the 3800 for some time now, I would recommend it. 13x19 comes out wonderfully on this printer.
Dave
I echo all the positive comments about the R3000. I've had mine for almost a month and have been amazed at the color prints it has turned out. I've done a few B&W, but have been concentrating on color. If you don't need bigger that 13x19, then the R3000 is a no-brainer. The only negative is the need to "manually" switch between PK and MK and the subsequent ink loss (about 1ml with each switch).
I am planning on using the Ink Supply (MIS) refillable carts with their K3 equivalent inks when the Epson carts run out.
Its only from photo black to matte.. the other way around consumes 3 ml... ouch
But I like my R3000... so far 😉
I have the 3880 and print out of Lightroom .The results are stunning . This is my first printer , it's amazing how easy it is to get satisfying results out Lightroom without much fuss ....
Yeah, forgot that direction ;-) Which explains why my PK cart is really low, probably too low to make another switch without a new cart. But, to be fair, I have made the switch several times since getting the printer while trying out various papers I've had on hand. Should have thought ahead and planned those paper test a little better.
Ditto, though - I love this printer, for both color and B&W and will be ditching my Epson C88 with CFS set and EZ inkset.
Ouch, that is over 10% of the ink!
Under what circumstances does one have to make the switch one way or the other?
Its more than an ouch 😀
Well, basically it depends on your choice of paper. For matte paper use matte black, and glossy paper photo black.
So you need to group your prints by paper type.
I have owned maybe a dozen inkjet printers, probably more. Used heavily. The Epson 3880 is simply the best one I've ever worked with, MUCH better than any of the other Epsons and FAR FAR better than any of the Canons, which tended to clog up a lot more. The 3880 is a remarkable printer that not only produces stunning results but lets you change the ink cartridge mid-print! Currently, I have a 3880 in my studio and two more of them for my students.
I too love the 3880, but have not used the R3000. Inks do last and last, I print a fair bit for various people and have only changed 3 cartridges over about 2 years. Likely 50% of the prints I've done (numbers not square inches) are 17x22"- I've gone through at least 150 sheets of that paper.
Hello all,
Best regards,
David
David, where are you seeing those prices? I'm in the market also.
Thanks!!
Try Epson.com if in the US. Their current price for new 3000 is $650 with free shipping. $999 for refurbished (good as a new one) 3880.
I have always bought direct from Epson. I buy a refurbished unit when available.
Ordered mine directly from epson.com and received it in less than a week as I recall. It's $650 after the $200 mail-in rebate and I'm still waiting for mine, but it's only been a few weeks since I sent it in.
