Shutter Release
If you are looking for a used one (and I am assuming it takes a normal one) I would say try the used bin at your local camera store, or try ebay. New most likely will be at your local camera store as well, or at any of the large on-line stores such as KEH or B&H. You will often find the called cable release as well.
I've received a number of used ones over the years and I can't stand having bent pins and all that stuff that sometimes comes with used cable releases. I wouldn't get a used one on ebay for that reason. I would also encourage you to test it in person to see if it's smooth, long enough, feels good, etc. regardless of if it's new or used. I've had some that don't even trip the shutter, so make sure you can test it out.
