Sony NEX-7 & Voigtländer 35/1.4
Nope. This lens has no noticeable color shift on any NEX camera. Granted, I just sold mine, because the corners never totally sharpen up, even when stopping down quite a bit.
FWIW, the Contax G 35 also doesn't have corner shift issues on the 7. It technically has a little bit of shift if you shoot a test target, but I'd doubt that you'd see it in use. The 35 Summicron IV is essentially the same lens design, so I'd guess it would behave the same. Both ZM 35s exhibit quite a bit of shift on the NEX-7. I've heard the CV 35/1.2 is fine, but I've not use it, myself.
Doesn't the CV 40/1.4 perform better on digital sensors? At least I recall that conclusion in regards Micro 4/3 cameras. I tried using CV's 15mm and 25mm lenses on my E-P1 a couple of years ago, only to realize that the pancake lenses manufactured for the camera perform better. Adapted lenses in the longer focal lengths 40 and up perform much better.
Quick question: will this combination produce purple and cyan corners, color shift and vignetting?
Thank you.
I have used this combination for some weeks now, and I can't see any of the above mentioned problems. So I'm rather pleased with mys NEX-7 and CV Nokton 1,4/35 mm.
Tikkis
Thank you for your input, everybody.
The color shift is really not a concern since it can be corrected by Cornerfix.
I tried that software (maybe not the right one, dont even remember where I downloaded it) and it did nothing for my combination of NEX and 21/4 lens. Picture looks weird, and I am generally not picky...
Maybe you can give me a link to the right stuff...
I have not used a 35mm lens that has produced colour-shifts in the corner of my NEX-7 images.
28mm lenses are risky and anything below is almost sure to show that effect but not 35mm.
However, I have not shot with the CV 35/1.4.
I've owned both the ZM 35/2.8 and ZM 35/2, and they both have quite a bit of color shift on the Nex-7. In fact, even my ZM 50/1.5 had a little bit of color shift on the Nex-7. I've seen evidence of shift with the 35 Summicron Asph and 35 Summilux Asph, but I don't own them to do more tests.
Download:
http://sourceforge.net/projects/cornerfix/files/
Information:
http://sites.google.com/site/cornerfix/
I have a few calibration files for M9, RD-1, NEX-5N for some Leica and CV lenses.
Some sample photos on my small site:
https://flyalf.wordpress.com/tag/m9_talk/
