I've never suffered that. Guess I used it up quickly enough. Used water from an untreated creek, too!
Was it a one gallon package?
How much film did you loose?
sorry to hear about your mishap, here are four basic steps how to avoid to repeat that unpleasant experience:
1) use de-mineralized water for the stock solution
2) when solving the powders, don't introduce oxygen into the developer by shaking the container, instead use a chemical mixer like this one
3) use a 5 liter wine bladder for storage, which is a very simple and effective way to keep the stock solution protected from oxygen and light at all times
4) note the date you prepared the stock solution, if older than 6 months or in doubt do a quick test with a piece of cut off film header
