Tadhgo
I would like to try something like this with two Olympus OMs, Does anyone else have a similar setup?
kinda strange thing to do to two bottom loaders... 🙂
I like that Mauser C96 tucked in the boots. Is this a WW2 photo?
I think we may have seen this before, is it a re-enactment.
Yes - the contraption is made from aluminium bar and box sections and nuts and bolts - all standard types. If you have drill press or a good vice and a power drill you could make something like this fairly easily. With a small milling machine something far neater would be possible.
It needs a re-build to simplify the arrangement, partly because one of the cameras (an SP) gets through batteries and so I either need to swap the camera over for another model or have a quicker means of getting at the base. The re-build has been delayed by other duties and once I've created some space in the garage where some of my machine tools lurk I'll make another version.
The design was based on the photo from that earlier thread cited above.
Regards
Andrew More
