GaryLH
My GXR and M-module arrived on Friday.
Focus assist is amazing. Works perfectly with my CV 28mm 3.5.
Nice to have a small compact body, my M9 stayed home all weekend.
I like it better than the Sony Nex implementation myself..
Gary
excited to get back in the A12 M mount camp, i suppose about end of next week i will get it,
the A12 module will enable a nice digiback for all my legacy lenses. For the 1.5 crop, superwide is not so easy to achieve, i was just thinking of adding the 28mm 2.5 module maybe (henrys got it at 274$ too...) omg this could blow away my gas for the new coolpix A,
697$ buys you a GXR grip, an super versatile M-mount A12, and an A12 GXR 28 2.5 module for AF wide angle work as big sensor GRD substitute
anyone here bought or has the 28mm module? how does IQ stack up?
Does 28mm module have a APS-C sensor? Or smaller?...., i was just thinking of adding the 28mm 2.5 module maybe (henrys got it at 274$ too...) omg this could blow away my gas for the new coolpix A,
I have ordered a body and M module. If the 28mm has a APS-C sensor I do not mind having one as well.
For me, I decided to go with the smaller sensor S10 module to cover the wider range. I hope it's at least a half decent walkabout lens.
It's an APS-c I do believe.
yes definitely aps-c sensor on that 28 2.5 module, seems like it's very low noise and sharp too, a friend of mine has it an loves it. apparently the 50 macro is even sharper, but I'm more interested in the wider fl s for AF
ARGGGGGGGGGGGGGGGGH. you *******s.
i just lost $287 on an A12 M-Mount kit. I already had a GXR with a 28mm fixed lens.....but i suppose i needed the A12 M Mount kit....so thank you 🙂
gas. gas. gas.
Johan, were you able to use the 21 SA on the Ricoh? Do you know if the 50 DR Summicron works as well?
Randy
Can't find the 28mm module on Henry's. must have sold out.......28mm 2.5 module maybe (henrys got it at 274$ too...) ...
I think they may have fun out but here is the link in case you want to try your luck in ordering it
http://www.henrys.com/70729-RICOH-GR-LENS-A12-28MM-F2-5.aspx
