LarsAC
I love it on film with a .58 finder. Never used it digital. if you need absolute sharpness into the corners look elsewhere I would say. Not a limitation for me though.
Lars
Lars
I am always surprised that people think that there are two kinds of lenses: lenses for digital and lenses for film. A lens is a lens, gentlemen, no more, no less.
Erik.
Note that i had several Color Skopar samples. They were not all the same. My current copy is super sharp and nicely symmetric, ill never sell it. I love the built and the tones the lens produces.
Is that the copy I used to own, Roland? Damn good lens, that one. I compared it with an Elmarit 28/2.8 ASPH and it held its own very well. Sharpness was on par except in the far corners at wider apertures.
It's a nice lens, but too expensive for what it is IMO. It was an economy lens of sorts when it came out years ago -- before Voigtlander moved to the high-end market.
Hi Erik, that's of course true, but some lenses are indeed more suited to digital than others. You can think of a digital sensor as millions of little buckets or wells lined up on a glass surface. If the incoming light from the lens is perpendicular to the sensor and directly hits the bottom of the wells, the light is recorded accurately. But if the incoming light is at an angle where it hits the sides of the wells instead of the bottoms, the light isn't recorded accurately resulting in color shifts. The steeper the angle of the incoming light, the worse it gets. That's why there's been a shift to telecentric "designed for digital" lens designs in recent years, and also why some digital cameras use micro lenses on the sensors. Film is not as sensitive to the angle of the incoming light. Any lens "designed for digital" will work equally as well on film.
Huh? Care to expand, because there is nothing wrong with the output from this lens in any way, shape, or form.
Y
Over time its price has inflated, not because it is such a great lens, but because it is now uncommon.
Yes, sure, I'm happy to expand. The Skopar 28/3.5 was easily purchased for around $200 or so used perhaps 15 or so years ago, and then at some point Voigtlander stopped making it (and most LTM lenses). I can't remember what the new price was back then, but I'm sure it was a lot less than the $500-600 it sells for used now.
Hi Jon, thank you for this very clear explanation, but I thought all this was passé since the M9 technology.
Erik.
