average price for the S2?
The user manual and repair manual are both often seen on EBay.
What is there about the camera's operation to indicate the need for CLA?
focusing wheel is a little bit stiff between 6 and 3 feet range and the lens a little shaking at the front otherwise seems fine, shutter works, curtain is in good condition...
Okay: from the description, try this.
1) LENS: There is a retaining ring on the back of the lens that holds it into the mount. If it is loose, the lens will be a little wobbly. One of my F1.4's was like this. SImple tightening of the ring fixed it up.
2) Focus stiff: The "proper" solution is to remove the focus mount and clean with Gas. I did that on one S2 that was really bad. On my others that were a "little Stiff", I took off the lens and back, set the shutter to "T" to keep the curtains open, and I squirted a little Ronsonol (lighter fluid) into the back of the helical. Work the focus and Dab up the now dirty lighter fluid with a Q-Tip. Worth a try before removing the helical.
hi Brian i've just tightened the ring on the back and the lens is ok now, i'll do the lighter fluid thing tomorrow, i think it'll be enough cause it's better now after working the wheel several times. this is a great camera, all the years and still works... 😀
Speedy
Congrats on your new camera and I am sure that you will get lots of pleasure from using it. As another S2 user I am sure of that.
Bob
also the focusing wheel is heavier towards to infinity, is this normal? and i hardly see the rangefinder view, is this normal too? or this is because i'm new to rangefinders? 😱 😱
Speedy
The rangefinder patch should be bright and easy to see, it may have faded over the years.
Bob
My really bad S2 required flood cleaning in gasoline. I removed it, soaked the helical, re-assembled. Smooth as butter after that. Seven screws and its out, but watch those shims under the screws of the helical. Small, and a real pain to replace.
Edit: I don't type fast enough. Looking good. 😎
Use the post reply button and go below the message block area to a button labled "manage attachments". Click on it and follow the prompts.
William
Thanks William...these are my first shots from a rangefinder and i'm a beginner to photography....so be cruel 😀
i have to learn this meterless thing, and some focusing skills i think...firstly...
That's some hard light to work with there. Have you seen this page http://www.fredparker.com/ultexp1.htm ? I found it very helpfull in learning how to estimate lighting much better.
William
