ranger9
Thanks, glad you enjoyed it! The lens front does make a difference in rangefinder cutoff (often it's a lens hood that's the problem) but the critical dimension seems to be at the base of the lens (the part just ahead of the lens mount.) From playing around with a caliper, I think the upper limit for base diameter is about 58mm -- much bigger than that and you won't be able to reach the release catch and might get cutoff in the RF window.
I have the old screwmount CV 50/1.5 Nokton, and its base is right at the borderline of being too fat for the release catch -- I can just barely reach it with a fingernail. It looks to me like the newer M-mount Nokton might be a bit slimmer, but it's hard to tell for sure from the photos on the CameraQuest website.
I still wish they'd designed in more clearance, but in practice, the mount limitation might work out as an unintentional "sanity check." The rangefinder's effective base length is only about 33mm (the Pixii website says it's 49.2mm, but I think they forgot to multiply in the 0.67x finder magnification.) That's longer than the effective base length of the Leica and Leitz/Minolta CL, the Minolta CLE, and the Bessa R and R2 (according to Stephen Gandy's handy chart) and only slightly shorter than the Bessa R3 and Epson R-D1, but it's quite a bit shorter than any Leica M model, and I suspect that it won't be accurate enough for close-range focusing of a lot of the fatter, wider-aperture lenses people might be tempted to mount on it. At least those people will get fair warning the first time they try to install a lens and then have to resort to a toothpick or the corner of a credit card to get it off again!
