hap
The Kiev external mount lenses should work with no problem. The rotation of the focus is the same as the Zeiss Contax. I used the adapter with an early black/nickel 13.5cm F4 and the Triotar 8.5cm F4.
The Internal mount lenses- will be slightly off, just like the internal mount Zeiss Sonnars. The adapter uses a Helical Pitch so the Cam travels to match the Leica RF as the lens rotates. The down-side, it does not travel far enough for the internal mount lenses made to the Zeiss standard,
I have several external mount S mount Nikkors short telephotos and one C mount Nikkor 85. Will those work ok?
