Raid, Pensacola has a few bayous but it takes an artist to capture them well. Nice work. When I have a problem with focus the first thing I do is try the tape test....nothing new....open the back, tape the film aperture and put it on a tripod and use a magnifier. I have one of these lenses Sn2201158[could swear this one "had coating" on the front lens] that had filter ring damage but I cleaned up and one coming in but WWII vintage, Sn2273620, coming in on a Contax III, both with "wings". Hope you find something simple was done and easily corrected though at $135 it should be in great shape to begin with. As for Contax I, I think it is underrated in the last version but you will need a viewfinder. I like the camera 50mm finder cleaned well...just fine, but for other lenses a separate finder would be necessary anyway even with the Contax II improvements. Another quick check is to mark the tape facing the front of the lens and have a look at it, looking through a SLR with medium telephoto lens set at infinity. With the Zeiss on infinity also you should see the tape markings as if under a microscope in sharp relief. [Just make certain the light behind the film aperture is bright enough for this.] Best of luck![The first Contax I that bought had grease around the first curtain spring spool compartment and looked very used....a lot of metal and grease grime cleaned out of it! The second an (f) model, from Belgium works like new well maintained and not so much used, nice!
