jejes
My slides looks like a bit out of focus. I share with you my entire workflow. If someone could help me, please PM me.
https://youtu.be/Cop-3G9pYLk
I've been told that this board works as an extender board to make it easier to get to the test points. I didn't see it posted here so here ya go. I'm waiting for mine to arrive.
https://www.digikey.com/en/products/...EXT-LF/2137335
Hi, I am not the most experienced user here but will write a short summary later today. In the meantime: do you have the manual to review? I suggest to read this first.Hello
I shoot 8x10 and 4x5 and I have purchased a ScanMate 5000. While I am waiting for the scanner to be delivered, I am trying to learn about ColorQuartet 5.2 and the appropriate settings for previewing and scanning. I hope I can learn from some of the experienced users here, about their preferred "Preview" and "Scan" settings. What to do and perhaps more importantly what not to do.
Thanks for your time and for your help!
Thanks so much. I actually decided to get a different scanner instead of ScanMate so will not need advise about CQ personally. But I am quite sure a writeup would be beneficial to the purpose of this thread and helpful to someone else in my position.Hi, I am not the most experienced user here but will write a short summary later today. In the meantime: do you have the manual to review? I suggest to read this first.
Finally found on a CQ cd.Good day !
Could anyone help me where can I download CT for Mac? Is that only for os9, correct?
Please post the original zip file here, i can host it!I reached out to ABC scan in Denmark, and received the software. I got everything working now (still having problems with the PCI Serial port and the dongle), and using run as date to get it to work. The scanner works now, took a bit of effort.
In the meantime, i got a second scanner with a mac and a dongle to have a backup scanner for parts.
This 'new' scanner i got, unfortunately it started showing stripes with the previous owner, and he had a 'technician' take a look at it, and since then, it only shows black images when doing preview/scan. This technician had taken it apart - so my guess is that he didn't align the light bulb correctly to the PMT 'sensor', hence not getting an image.
Before i start taking it apart to check if i can correct the alignment, (if that is even the case), anybody does have any tips how to go from here? The scanner is correctly recognized, and spools perfectly, does everything as my proper working one does.
appreciate the help! 🙂
I think thats a DIN 41612 connector. You can get those from aliexpress.I've been told that this board works as an extender board to make it easier to get to the test points. I didn't see it posted here so here ya go. I'm waiting for mine to arrive.
https://www.digikey.com/en/products/detail/twin-industries/8196-EXT-LF/2137335
Did you run QC in administrator mode? It needs to be run that way to work.So a step further and stuck again, I got one of the tested adapters, an Adaptec 2906 (PCI) and a PCIe to PCI extension. The card is recognized and shows up in the device manager in win 11, the scanner however still does not.
The scanner boots into "on" and "ready"
Running the CQscan tool (v 5.2) the "No scanner found" message comes up and I can see the "operating" LED blink up for a fraction of a second. If I let the program just sit for a second and then press retry, the process takes quite a while (2, perhaps 3 seconds) and the scanner "operating" lamp turns on constantly.
This leads me to believe that there is some SCSI communications even if no device shows up in the device manager, so I assume the card and cable at least are working.
My theories so far are:
- the scanner is toast (I hope not 😀)
- That CQ 5.2 is too new for ScanMate Plus? It is after all a very old scanner and I've not managed to find many users of it. Any chance someone has an older version for windows lying around I could give a shot?
EDIT:
Or an old color trio turns out color trio 1.1 (found that somewhere here and got it installed in an XP VM) is too new for the ScanMate Plus, turns out it only supports the ScanMate Magic Plus and ScanMate Plus II
Does anyone have an idea what software is needed?
